Indicator makes rear lights pulse???
(In Topic #218621)
I'd noticed this a while back whilst undertaking pre MOT checks. I'm assuming this is an earthing issue so cleaned up the earth point in the corner of the boot, the multi-plugs to the light clusters and the under bonnet earths to gearbox/chassis. They all appeared OK anyway and didn't really improve things…..
Rest of the 'lectrics all appear to be present and correct and work fine.
Any ideas where else to look or what else I could check??
Corrosion in the Bulb sockets can cause this as well. I usually remove the bulbs and clean the sockets with Steel wool to polish the bulb base, as well as the copper finger. I also clean the attachment of the ground wire to the plate, and tighten the crimp.
Now Pulsing is also a Voltage issue as in how much deflection is there in your VOltmeter.
So you could be under powering them.
Check that you are getting 13.85 to 14V out of your alternator at the battery connection.
If you disconnect the battery and remove the regulator assembly you can clean the contact points of it. I have seen as much as a 1/2 Volt gain on my alternator when doing it.
Alternator Tune up (Bosch 2 wire) | Volkswagen Owners Club Forum)
Also you might want to add a ground wire from a case nut on your alternator to the engine I use a Valve cover nut.. as the only grounding of the alternator is from the mount bottom bolt and the pinching action of the bronze bushing moving in steel to an aluminum frame of the alternator so you have 3 different metals being used for the grounding. There is a electrolysis action of differential materials and passing current through them and the upper bracket bolt Steel to aluminum and back to steel, and if you don't clean them things you can drop current and voltage because of it.
Will double check battery voltage and the alternator tips
This can also reduce the Pulsing of the rears.
As I said separating the grounds from the left and right sides rear to their own Ground path is a really good thing to consider, it's only about less than 2 foot or wire per side and a couple of Ring connectors and a couple of female Blade connections.
