Indicator & Alternator Help
(In Topic #222851)
1980 Tin Top 1.8 KR
Hi All,
Had a little search but some of the info had disappeared.
Issue 1 - I'm going to the dark side & have 3P airlift ready to fit but they have mentioned upgrading my Alternator & Battery.
My Battery is only approx. a year old but my alternator died just before the car went away for Winter so I'm looking for some suggestions on upgrades / replacements to help support the compressors.
Engine is a 1.8 KR from a mk2.
Issue 2 - One side of my indicators have stopped working. Lights up a little on the dash but nothing to the lights - front or rear.
Checked the lights to make sure they are working & one side works fine. Any tips for things to check before I get them re-wired.
Thank you in advance : )
Faye
Faye
- Project 5dr gl - 16v Kr - R1 Carbs = Back On Road
Check all your fuses, and Ground to the rear indicators.
You can add additional grounds using a length of wire to the ground points on your Lights, to a Bumper bolt.
Grounds do get accidently knocked off with throwing things in the boot.
Alternator's need to know which type that you have, the Motorola (wires plug in to a socket on the Voltage Regulator)
Bosch that has 2 Studs one large and one little. The little one should have a blue wire on it. If the blue wire is disconnected, and or the wire is broken, then you can get a Bad Alternator indication as the battery will not "tickle" the field to start charging.
The Bosch comes in 3 varieties that I know of over here,
55-60, 90, and 120Amp.
The Motorola I think goes from 55, or 65A…
sorry just seen, this, the lights can be faulty hazard switch try on/off a few times or half way. give the indicator relay a love tap also. lack of use and moisture kills these switches and relays.
Thank you 😊
Ordered a new relay & that didn't work but I'll have a look into the Hazard Switch!
FayeC said
Thank you 😊
yes its a funny switch seems to create havoc when they go faulty.
