Immobiliser fitting - best circuits to 'cut'?
(In Topic #227854)
Before I put the dash back in I thought I'd fit an immobiliser. I had one in years ago, but it packed up so I removed it completely and tidied up all the wiring. Anyways, the one I have bought can cut 2 circuits, but they have a 10 amp max limit. I was thinking of fuel pump and coil supply.
Questions:
- are either of those > 10 amps?
- Should I cut the supply to the relay 'coil', or the supply to the fuel pump?
- Anything better I could 'cut'?
Ta!
J
paceman said
Hi folks,
[*]Should I cut the supply to the relay 'coil', or the supply to the fuel pump?[/*]
If it can do 2 circuits it would be "AND", not "OR".
Also you don't mention if its fuel injection but obviously the carb car doesn't have a fuel pump, so you'd not have that circuit to alter.
When you say "the control side of the fuel pump relay" is that D13 red/yel - trigger for fuel relay?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Hypothetical situation is that they have stolen the car and are driving. They pass through the geofence so the tracker cuts a circuit. Don't want them to have an accident and damage the car.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
You can set it to alert you if it moves, goes outside a certain area, beyond a certain speed etc. Bizarrely enough you can actually call it and hear what's happening inside.
Some have the option to cut a circuit either by text message or if certain conditions are met.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I think I'll do the fuel pump relay and the TCI live - hadn't thought of that one.
Now I just have to get behind the fuse box which will be fun - too many wires!
J
the_whip said
Is that the least dramatic way?
I'd cut the fuel pump circuit. As Steve said it will be like running out of fuel so they would have time to 'react' to it.
paceman said
Thanks chaps,
J
If you go done this route, you can do all you wiring in the engine bay . If you take the spade terminals out of there connectors(at the coil) you wouldn't need to chop wires and it could be put back to standard at any time. Just hide wires so it can't be seen.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I can cut the coil wire easily enough, as illustrated here:
But the supply to the fuel pump relay 'coil' is a bit more of a challenge. As you can see in the diagram below, the points I could cut are actually look like tracks that are part of the fuse box as opposed to wires…
I don't think I can actually cut the supply to the fuel pump (G6 in the diagram above) as the current draw of the pump is > 10A (well the fuse is rated at 15A so it's probably close to 10A). Any ideas?
On the plus side, I've finally worked out that the D13, E14, E5 numbers refer to the pins on the connectors - always wondered what they meant!
Thanks,
J
On further examination, I don't actually think the fuel pump would run anyway if I cut the Coil wire I indicated as that forms part of the relay 'coil' circuit…
You'd never believe I did electrical/electronic engineering at uni would you!!
J
To protect a second circuit I fitted a hard start relay on the starter, as the switched side of the relay draws very little current its ideal for an immobiliser circuit, final result is no ignition and no crank when immobilised, seems to work very well.
For that little bit extra you could always add a push button inline with your starter circuit (when relayed) this means the button needs pressing to crank the starter, bit ott perhaps.
cheers.
I did think about the starter as I'm also going to fit a hard start relay (in a nice box alongside my headlight relays). I can immobilise the coil and fuel pump in one go as Steve suggested above, so starter seems like a good 2nd.
Out of interest what size relay did you use? I've got a 40amp one which I feel should be sufficient for the solenoid (given it currently runs through the ignition switch.
J
You will cut the solenoid wire and one half of it goes to the Contacts the other goes back to the ignition switch.
You will notice afterwards that your starter spins a bit faster as you take the load off the ignition switch and shorten the route of current from the Battery direct to the relay, then from the relay to the starter and the high current never leaves the engine bay.
I used an 80A relay in mine set up, but only because I had some in the garage, I’m sure a 40A will be more than edequate given the vw set up. As Briano states my starter does crank a bit quicker and the high load is now taken away from the ignition switch.
Dave.
