How to add fuel pump for dual webers
(In Topic #233766)
The previous engine had a mechanical fuel pump so I don't have any old fuelpump wires I can repurpose.
I've got a big white/pink wire that used to go to the manifold heater. I've read that I can use this circuit for the fuel pump too.
So if that is correct, what is the best course of action?
Should I mount a fuelpump against the firewall so I can use the pink/white wire?
Something like a Facet fuelpump.
OR should I place one closer to the fuel tank and pull a new wire?
Hope to hear, thanks in advance!
Last edit: by Weber16v
