High beam light on dash not working
(In Topic #233650)
Hi All,
My high beam light on the dash is not working, is this an easy fix?
When I say easy I mean is it as easy as taking the speedo/rev counter head out and replacing the bulb or is it a bit deeper?
Tim
Tim
Chairman
I did mine by using this guide so it's got to be easy!!!
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrical-faq_2%2Fhelp-main-beam_2
Thanks Dano, So do the LED's just push in or do they have to be soldered in place?
Chairman
They push in. Try and get normal bulbs, not an LED because they need a resistor (or something).
The ones I used had a longer 'leg' on one side. Unfortunately I didn't take a photo of it. I got it from Maplins but they've closed down now so any decent electrical shop should be able to help you.
The blue you see is a cover with a white bulb underneath. I got a blue bulb as a replacement, I think…. I did mine in 2013.
I tried changing the LED in the dash but still nothing, I have on occasion seen mine come back to life, so leads me to think it is the stalk itself.. so keep that in mind too!
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
