Heater fan not working
(In Topic #177341)
I've finally got back home from work to drive for the first time my '91 cabrio just to discover that the heater fan doesn't work. (Just the fan because hot air come in fine…)
I tried to search for solution, but most of them talk about the fuse and the relays…
The first thing I looked at is the fuse n. 14 that was a 10 Amp, tried with a 15 (not having the 20 required), and after turning on the car I tried to switch on the fan, but moving from position 1 to 2, and from 2 to 3, I hearde something like a "BUP" coming form the switch… just to blow the fuse (i was expecting it…
than if the fan i ok, i would like to test the switch, how to do it???
in the fusebox I only have the relays related to the fuel pump, the load reduction, as long as the intermitent wiper with horns and emergency/turn blinker ones. so no A/C relays is in place…
another strange thing is that i have no no. 5 fuse (fuel pump) but the n. 6 is in place, any idea??
hope to hear from you soon for help.
Regards,
Mirko
edit: I'm adding a link to the picture of my actual fuse box…
Last edit: by FatalPuppet
I was looking for a relay for the bro in laws T2 a few weeks ago and thought of borrowing one out of my cabrio but the one I pulled was all corroded. No sign of a leak so much have been a previous leak that caused it.
