Heater Blower works with keys out of ignition - where is it earthed?
(In Topic #234450)
I woke up the other day to a flat battery, so feel something is amiss and draining the battery constantly, but I had no lights/blowers/etc left on overnight, so not sure what! Hopefully the two issues are related!
I don't think earth is the issue, I would check my X circuit.
Or ignition switch.
Briano1234 said
The earth for the blower is usually on the left side of the heater box, where the Star Ground is.
Or ignition switch.
Thanks for the reply! What do you mean by X circuit? Not heard that term before
Tech Groups
The "X" Circuit from the Ignition Switch. | VW Vortex - Volkswagen Forum
Briano1234 said
X circuit, is also called the load reduction. There is a relay that makes supplies power to the blower lights and other high demand things, it is turned off at Start, and at key out, in the run position it is engaged or energized.
Tech Groups
Nice one, thanks!
