Heater Blower works with keys out of ignition - where is it earthed?
(In Topic #234450)
So, woes of the Golf continue! Got my heater motor working again, now found out it seems to turn on with the engine off and the keys out the ignition! Guessing it's earthing incorrectly somewhere, but does anyone know where it earths to?
I woke up the other day to a flat battery, so feel something is amiss and draining the battery constantly, but I had no lights/blowers/etc left on overnight, so not sure what! Hopefully the two issues are related!
The earth for the blower is usually on the left side of the heater box, where the Star Ground is.
I don't think earth is the issue, I would check my X circuit.
Or ignition switch.
Or ignition switch.
Or ignition switch.
Thanks for the reply! What do you mean by X circuit? Not heard that term before
X circuit, is also called the load reduction. There is a relay that makes supplies power to the blower lights and other high demand things, it is turned off at Start, and at key out, in the run position it is engaged or energized.
Tech Groups
The "X" Circuit from the Ignition Switch. | VW Vortex - Volkswagen Forum
Tech Groups
Tech Groups
Nice one, thanks!
