Headlight loom upgrade
(In Topic #208654)
Thanks in advance!
Here is the link to the harness wiring that I did. The one on top is for a 3 relay, and the one ont he bottom is for a 2 wire relay.
New design for Headlights Relay - Topless Rabbit Forums
If it helps, here's a photo of my loom. The wires I mean are the 2 blue ones (not red, sorry!) with the ring connectors that come out of the yellow blocks.
compare the harness headlight to my drawing I forgot to add the ground to the brown path.
I will correct that.
I have "fixed" my drawings.
only 1 fuse and 2 relays means there is no failover there, if a relay goes you loose both sides, and if the fuse goes you loose ALL of the lights.
Ideally you want at least 3 relays and fuses, 1 fuse and relay per side for dipped and 1 fuse/relay for main (you don't use these often so just the 1 is probably fine, but feel free to add an extra fuse and relay if you want!)
I'll have a look at your diagrams Brian and see if I can figure out how to add the extra relay and fuses. Wish me luck!
