Hazards and Indicators not working?
(In Topic #182663)
What have I done?
I've checked the blue/white wire that goes to the hazard and this is fine. Out of ideas other than properly tapping into the stalk wiring rather that splicing using the little clip around blocks?
What I really need help here with is finding out which wires are original and where they should be going etc. Starting with the block connector on the column, the current order is:
Thick red = Thick Red *brown wire has been spliced off this*
Yellow/Black = NOT CUT OR MODIFIED
Grey = NOT CUT OR MODIFIED
White = NOT CUT OR MODIFIED
TWO thin black wires = soldered into one brown wire then back into TWO thin black wires
Brown = thick red/black wire
Can anyone help me? Even a pic of their column wiring would be so much help
30 - red - live
15 - black - ignition live (2 wires here)
50 - red/black - starter motor
X - black/yellow - x-over relay trigger
p - grey - parking lights
basically anythign that has been tapped into those wires needs to be snipped off and binned. the wires above go from switch to fusebox without any dodgy tappings into them
Any idea why the starter red/black is connected to a brown wire instead?
Will get on it tonight and repair the bodges, at least its not as bad as I initially thought! Just got to sort out the hazard/indicator issue now.
Do you think a relay could be at fault? The wipers don't work either…
the hazard relay is #21, wipers is the 19 relay. the 17/18 relay powers the wipers, lights, blower etc so check that as well, triggered by the black/yellow wire to ignition switch
for a start you have an extra wiper relay in the a/c relay socket, and a low coolant warning relay in the rear wiper socket (probably goes in the spare socket above fusebox, check wire colours it has red/yellow or blue/yellow, plus black/yellow, brown and red/brown)
The car had a quite bad moisture problem when I bought it, could the fusebox be at fault?
Hopefully anyway i'm starting to lose faith
