Hazard warning lights half working?
(In Topic #233868)
Only passenger side flash, indicators work fine?
The cabrio is due for it's MOT so I have been giving it a quick once over. Everything seems OK apart from a weird thing with the hazards.
When activated only the 3 passenger side lights work (bumper, wing, rear cluster) all three on the drivers side don't flash, remaining off.
When using the indicator stalk to indicate right (drivers side) the 3 lights work perfectly, as do the passengers side when indicating left. The tell-tale in the hazard switch flashes and it doesn't flash the drivers side with or without the the engine running.
It's only done a few hundred miles since last year
Any ideas what the problem is and how to fix it???
I also recon the switch may be at fault.
I flicked the switch on and off a few times and that seemed to get it to work 9 times out of 10. Life has taught me that when Mr MOT man does it it will be 10th and not work. So I disconnected the battery, extracted the switch, very carefully pulled it apart and cleaned up all the contacts, inside and outside.
et voilą ! further proof that lack of use is no good for cars, even those that spend most of their life tucked up in a warm dry garage.
