Glow plug relay in slot 2 ?
(In Topic #239974)
Howdy folks. I fitted an aaz engine in my cabby. Can I use slot 2 in the fuse box which would have had the fuel pump relay?If so does anybody know the part number? Thanks
It is probably better to use a fuse panel add on at the top. Then you can wire it correctly as you want it.
https://vincewaldon.com/2008/09/30/how-to-pimp-your-glowplug-wiring/
https://vincewaldon.com/category/volkswagens/
Thanks Brian , I was looking at that yesterday I'm a grease monkey electrics make me dizzy . I'll look at it again and make a list of what I need . Looking for easy options as always with wiring . My Haynes diesel manual showed slot 2 for glow plug. Thought it be simple as that. Thanks for reply mate
