G60 Rallye lambda wiring
(In Topic #204474)
this may be enough to sort your issue, if not there may be some other fault which is causing the ecu to go into limp, 1st check is blue temp sensor resistance and wiring back to the ecu
coolant sensor should have a wire to pin 10 which is usually brown/green and the other to the common earth on pin 6
for lambda heater ignition live will do you fine
