G60 no spark
(In Topic #220800)
Does the ecu trigger the green earth?
Does it look at the dizzy hall sender for this?
Can I test the coil by just giving it a 12v and local earth?
make sure the rest of the ecu is wired up properly, theres a cranking live to the ecu pin 1 which goes to a spade plug on C/18.
you should have good 12v both with ignition and when cranking to the black/yellow to pin 14, this is also shared with the ISV and isv should be buzzing ignition on
hall sender is what tells ecu it needs to fire the coil so would be on the list of suspects if you got no spark
