Fuse box
(In Topic #208573)
Hey, I'm not sure if I'm missing any fuses on the fusebox, I've attached a picture, would be a great help if anyone could let me know (I've attached a picture….) Many thanks
Not all fuses are used in all cases.
www.cabby-info.com has a diagram and pictures of the Cabriolet fuse boxes for all years.
Briano1234 said
Posting the year of your car, and model goes a long way in figuring this out. Depending on your optional components depends on which fuses may or may not be installed in your car.
Apologies - it's 89 Cab - thanks
Yours seem different from my 1988 Gti cabriolet.
I've NOT got electric windows or electric roof.
The 99 reply is upgrade programmable intermediate wipe from original 19 replay and 292 is a lights left on buzzer so ignore them.
62 is my fuel pump relay.
mark1gls said
Is your car carb or injection?
It's a carb mate - it doesn't have any electrics either apart from an electric aerial.
http://www.clubgti.com/showthread.php?219775-Fusebox-FAQ
Yours is 30 amps (Green)
May be worth finding out if you have the right amp fuses fitted as you car is different from mine.
mark1gls said
Some of the rating on your fuses are higher than mine, No.3 in from left mine is 15 amps (blue)
So according to http://www.cabby-info.com/images/Electrical/87-89FusePanel.png & the picture attached
i have the following fuses that is different to the original settings:
Seat belts (I have 10, should be 15)
Tail Lights, Parking lights(I have 15, should be 10)
Cig Lighter, Radio(I have 30, should be 15)
Fuel Pump(I have 10, should be 15)
Relays
Fuel pump is 1 not 62
Idle Control is 61 not 57
Could this cause an issue??????
just swap the fuses to match the list above, apart from you don't actually need a fuel pump one so you can pull that out entirely
