Fuse box and wireing diagrams
(In Topic #197884)
Iv been looking about on the internet and the owners club for a good few days now trying to find a fusebox diagram for all the fuses, relays and a full wireing diagram for my 82' tintop 1.3 cl.
I literally cannot find a thing, I need the information to finnish off my conversion. Bought the car with a polo GT engine in it, the wireing was shocking, i'v converted it onto twin dellorto carbs; what im trying to work out is whats polo loom and whats golf loom, a good colour coded diagram of all the wireing and where it goes, and a fuse box diagram. I need as much information as possible.
Thanks!
Miranda the 1982 manilla Green 5-door tintop
mark1gls said
It should all be in the haynes manual.
My year/model isnt in the haynes book, those wireing diagrams in there are very confusing, surely somebody must of made or knows of a clear colour coded diagram?
Sounds like with all due respect that you've got a bit of a Waldorf Salad mix there, so clearly in no normal manual.
But then you know that!
However your best bet is John
He has an extensive range of wiring diagrams across many models if it helps!
golfcabrio said
I'm not so sure you're going to find what you're looking for.
But then you know that!![]()
However your best bet is Johnrubjonny
He has an extensive range of wiring diagrams across many models if it helps!![]()
i didnt think i'd have much luck
http://www.clubgti.com/showthread.php?173722
diagram scanned out the haynes is in my sig, g1wiring81.pdf
