fuel pump relay
(In Topic #215253)
and does anyone have a wiring diagram that you can understand for the s1 gti?
thanks
andrew
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Andrew
You could use the later fusebox relay, but that would need an inline fuse plus a different relay holder 867937501 and the 30 and 87 terminals use larger 9.53mm non-insulated latched terminals
wire your relay like so:
30 - H spade
15 - ignition live, G spade 3 will work
87 - fuel relay power junction box near the A pillar
31 - earth
31b - rev counter feed from fusebox, tap into red/black from coil
Mark carter from classic-vw.co.uk used to do factory style relocation kits back in the day, drop him an email see fi he still has some
Can anyone tell me what this green and black wire connects to? And should there be anything connected into the red and white wires going into the t connector?
Andrew
the spade block you found is the fuel pump power distribution block. the fusebox pin above goes there, plus the yellow/red fuel pump power wire and the red/white for the WUR and AAV
Hi read this and thought I can do this but but went to do it and got stuck! Can you break down the idiots guide to complete nob heads guide 😉 That's the level I need Please
30 - H spade. - what's this ?
15 - ignition live, G spade 3 work- what colour would this be
87 - fuel relay power junction box near the A pillar what colour?
31 - earth got this I think
31b - rev counter feed from fusebox, tap into red/black from coil. Found this
Thanks again
http://clubgti.com/showthread.php?219775-Fusebox-FAQ&p=1945620&viewfull=1#post1945620
the wires on the junction block are red/yellow and red/white usually, assumign its not been messed with. you cant miss it, clear spade housing 2 spades on 1 side and 1 spade on the other kicking about near the A pillar (has wire to fuel pump in there, and another from the engine loom for WUR and AAV)
