Fuel pump relay
(In Topic #209606)
The fuel pump relay is toast in my car
Fuel pump relay
I borrowed this from a mate it looks different
is it the wrong one ? Thanks
There were about 4 styles of relays. Not all are correct.
The list of correct relays are at www.cabby-info.com
http://www.cabby-info.com/Files/Relays.pdf
Fuel pump relay
Cheers mate dx is engine code, so its k jet , innit?
Vw heritage do the one you require mate, non fused 321906059G is one that is fitted to 3 of my cars 88 to 93 reg
On the drive
Myvalver 89 GTi Grey mk2 16v
What year is your car and what type of fuse box do you have, bullet fuses or blade type fuses?
Where is the fuel pump relay, fitted above the fuse box or in the main fuse box with all the other relays?
My later style fuse box from 1988 cabriolet, blade fuses, relay with no62 is my fuel pump relay.
Fuel pump relay
Alright Kenneth are you boasting again about your 3 cabby? Yes that's the part no I'm going with off the toasted relay. Cheers mark mines in same position, I bridged terminals on fuse box and pump came on do happy days it's not busted
Haha not boasting..otherwise I'd say 3 running..1 donor…1 in a paint shop what did run and a mk2 16v… and still i dont really have a clue when any will be finished.. glad you identifed the issue..and that you've got a pair of relay coming(1 spare) unless happy with wire bypass . Now just to confirm that everything else is good.
On the drive
If you car was fitted with a no62 relay there is 1 here on eBay.
http://www.ebay.co.uk/itm/VW-Audi-Seat-Skoda-relay-No-62-443907385B-443-907-385-B-/272552153569?hash=item3f755fd1e1:m:mdjohYWAXK2cctBoERgLwtg
No62 relay has a rev limiter built into it and is used in later cars.
There was a guide on here some where about what the different relays fit and do.
I've tried a new repo relay and it was rubbish quality and my fuel pump primed every time I turned the ignition on which I did not want so I found a 2nd hand relay and its back to how it was before, no priming.
toasted relay is CE1 fusebox type, mk1/2 83 onwards kjet 8v GTI ones will work. some of them have rev limiters in, some dont. you can go either way, just note that if the relay has a limiter in the rotor arm is plain, if it doesn't have the limiter its the rotor arm which has the rev limiter. so be aware if you have a plain rotor arm and a non-limiter relay then you wont have a limiter any more
2nd one is for the older ceramic fusebox which is why it wont fit.
Fuel pump relay
Cheers folks , yes it has the plain rotor
ok so technically you need a rev limiter relay, if you're worried about that. or you can get a non-limiter relay and change the rotor arm if you prefer
Fuel pump relay
Ok so, haven't bought relay yet .any idea what part no is for the one I need?!
number / vw part number/ kraker / GSF
2 = 443906059A/321906059D/E = no limiter (superceeded by 321906059F)
3 = 443906059 = no limiter (superceeded by 321906059E/F)
62 = 443907385B/321906059G / 24.1400.30 & 3.300.220 / ? = 6.5k limiter
63 = 321906059F / 24.1400.20 / 935VG0090 = no limiter
65 = 321906059H / 24.1400.40 & 3.300.230 / 935VG0080? = 6.3k limiter
Fuel pump relay
Cheers rj. Thanks
Hello,
Sorry for what might seem like a really silly question!!
My 1990 Mk1 Cabriolet (DX engine code) is currently broken at a local garage. Fuel pump not priming at all I believe, mechanic has traced fault to damage on fuse board following what appears to be a corroded fuse that has spread to the board.
I need a new fuel pump relay fuse but I'm confused as VW Heritage has two types that both fit my car. The relay from the car has come from position "2" and just has the marking of 1902 !
I need to source a new board and new relay but I am unsure on what relay I need please??
1990 - Cabriolet GTI 1.8 (DX)
My 1988 DX car has never primed the fuel pump before starting as it does not need to…
They can test the fuel pump etc by removing the relay below the fuel pump relay and putting it in the slot for the fuel pump relay then the pump should run as soon as the ignition is switched on.
Other way is get a bit of wire and bridge the 2 bigger connection where the fuel pump relay is then the fuel pump should run even without the key in the car.
Ive got the priming type.. from mark carter.
https://www.classic-vw.co.uk/
Think buy 2 as a spare should always be in your tool kit.
On the drive
you need the later type fuel relay, some have rev limiter built in and some dont it depends on age of car. if you check the rotor arm if its plain the limiter is in the relay, if it looks funky then its got a rev limiter rotor arm in
Fuel pump relay
I meant to update this , but as it’s another project I’m a bit slow. So my relay was toast I got a new one from gsf but it didn’t work so I’m starting the car with a jumper wire in
Place of the relay
Place of the relay
