Fuel pump relay help
(In Topic #216155)
When it was wired in previously it was wired independently to the fuse boxing the a relay but I think only to the ignition using permameny live coil wire and ignition live ? I think,
So bacsically can I have the idiots guide including wire colours and anything I would need to do it properly , as although it ran and ran well I don't think it was particularly safe!
Thanks again for all your help
Part number of relay and brand would be nice as well.
The fuel pump is powered off the Coil usually.
The fuel pump can be located with in the Fuse Panel, and or as an accessory port on the top of the relay panel as a TSB redirected it there on certain models.
Which is why I need to know, and if the pump was whining, dependant on the year and type of injection, you may have 2 pumps and a sump, and if the second or intank pump is bad that can cause the main to whine louder than a child at a candy store when you try to pull them away.
Thanks again
Kris
put 2 wires on e/14, one straight to the fuel pump and one with a male spade on it. then plug the WUR and AAV red/white power wire to the spade
What could be not right??
I've checked for leaks and have none I pulled the plug out thinking I might have flooded with it and they were all dry as nun, so I don't think any fuel is getting to block? I thought accumulator ? Or pipes but don't see how it was working one minute and now it's not ?
Thanks in advance
Kris
http://www.clubgti.com/showthread.php?195423
go back and look at the pipes you replaced, make sure non of the banjo bolts have a filter in where they shouldnt. pull the feed pipe off the pump and look for a mesh basket which might be blocked. I've had non-return valve fail and not let fuel thru, plus I've had fuel filters go all of a sudden too
