Fuel pump fuse blowing
(In Topic #184553)
Just another chapter in what so far has been hellish mk1 ownership
Recently I've been fiddling with fuel gauges trying to get a read but sacked it off.
the other day the fuel pump relay blew. No idea why, I just replaced and it then ran fine yesterday.
today when I tried to crank the fuel pump fuse blew again. Replacing the fuse has made no difference.
so here's what I've done in search for an answer;
bear in mind that the fuel pump has been running without issue and has been providing plenty of fuel. It's an '83 Dx engine. Oh and it hasn't seen any water for 5 months
pump will run when bridged
tested continuity of both fuel pump wires both fine
tested voltage across fuel pump fuse terminals and get 12.38v
tried two different relays and no change
I've also turned the ignition with both fuel pump terminals insulated and still blows
ideas please cos I'm getting very close to fire bombing the damn thing now
Why did I start this
Blew the fuse
Last edit: by Birtymeek
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
I replaced Fuel tank in lift pump, fuel filter and this cured mine.
So I'll jack car over on one side (as it has about 4 gallons in it) tomorrow to have a peek at that.
As for the wiring, I've listed the checks I have done so far but nothing conclusive
Sometimes there's nothing definitive, it's a case of investigation, trial and error fella.
Investigation begins today then
Disconnected the side which leads to the accumulator. Tried and fuse blows.
Got a seperate battery and two wires (positive with an inline 15a fuse. Placed this on the pump and works great guns. Fuse then does NOT blow.
This makes me think more electrical side of things am I right?
So im thinking not a blockage issue but wiring somewhere, but where
Have a look at Rubjohnny's comments on this link regarding warm up regulator, I previously mentioned the thermo time switch but meant to say WUR (warm up regulator) as he says, uses the same 12v supply
I turned my attention to the wur as mentioned. Mine was dangling as i e been trying to sort system pressure. Changed the wur to a spare i had. Fuse still blew. So tried another spare wur and sucess!
Since then ive tried the initial wur and the other spare and neither have blown the fuse so im thinking it must be something to do with the wur wiring plug.
Then after this sucess the car wouldnt fire because some idiot in a rush to get things back together before work, put the fuel pump wires the wrong way around
if no visable damage look behind the fusebox for the red/white engine loom plug, where it joins to the fuel pump power pin E/14. unplug that to isolate the engine bay power wires.
if fuse stops blowing then good news in that you have isolated the problem, bad news is you'll have to dig in the engine loom till you find it!
Think I need to find a k jet specialist to hand it off to and pick it back up sorted
sounds like it needs a proper once over top to bottom
