Female spade size
(In Topic #222986)
Does anyone know what female spade I require to connect to this spade?
Many thanks
So what are you trying to connect?
Briano1234 said
That is a Pin type of female connection, that is it usually resides in a plastic (nylon) connector.
I was going to connect the wires from the amp to this spear ideally …(I didn't want to splice because I can just put everything back to normal if I chose to one day…)
