Female spade size
(In Topic #222986)
Hi All,
Does anyone know what female spade I require to connect to this spade?
Many thanks
Many thanks
That is a Pin type of female connection, that is it usually resides in a plastic (nylon) connector.
So what are you trying to connect?
I was going to connect the wires from the amp to this spear ideally …(I didn't want to splice because I can just put everything back to normal if I chose to one day…)
at a guess a 2.8mm spade would fit, measure it and see? secure with tape after to stop it coming apart or shorting out
