Electric windows
(In Topic #223640)
Hi Guys well the journey continues..
More electrical problems.
Just need to figure out this mess'
Well thoses aren't your Daddy's window controllers, as they aren't OEM So you are out of my wheel house.
Since it is ford, the black is probably ground.
Right sorted this out just wondering where I can pick up ignition live any suggestions? Ive used 2 & 5 of G spades already
Well vw used switched power….
I suspect that you could find a 30 Live run like at the Courtesy lamp wire but the issue is that you may want to run a new wire off the Battery as it has to be a good sized gauge as in 1.5 or even 2.0…..
I would fuse it either way.
Electric windows
What loads have you got through the G spades?
Could you piggy back connectors?
Something like this?
Just wondering about fuses though.
You could run inline holders
Where are they currently supplied from?
