Dipped beam issues
(In Topic #199937)
Help
is there a separate relay for dipped/ main beam ? Or is it my stalk on the way out ? Any help please
thanks
ian
Failing that anyone know a decent sparky in the Redhill area
Ian
Thank you for the tip,I went through every earth, changed both stalks for NOS,cleaned out every switch and earth on the dash - and hey presto it started, still odd problem with washers and dipped beam until i moved the rheostat for the speedo dimmer with the switch out and saw it glowing !!- changed the switch and all is good againmark1gls said
I would look at the switch, the stalk seems ok as the high beam lights will only come on with the headlights on unless you are flashing them which is why yours are working.
anyone want a sportiline?
