Dashboard & dials poor ilumination
(In Topic #217301)
Any DIY solution?
Yes, the regulator is at max. position.
Is it easy to change the lights? How?
I used the search but didn't find a post about it.
Thank you very much, guys.
Harder fix is change the bulbs for higher wattage as usually it's 1.2w for the Rev counter and speedo and 2w for the clock/MFA. Swop them all 2w bulbs or try LEDs but not sure which type you need.
You will need to take the instruments out to do this, make sure they all work before putting it all back together as sometimes the bulbs do not make a good connection first time.
https://www.ebay.co.uk/itm/4pc-VW-Golf-Jetta-Caddy-Mk1-Mk2-2-0w-White-Base-Dash-Light-Bulb-Speedo-ClocksD10/152960099428?hash=item239d21e464:g:stkAAOxy0bRTB8Tb
Is it difficult to take the instruments out?
Thanks again
spncabby said
thank you very much. First of all I'll try with the dimmer.
Thanks again
No, you just have to be careful of the mylar.
What I have done is to go to a breaker and get the warning lamp holders off a Honda Civic. Go to a good parts store and get replacement WARNING bulbs for the
Same car you took the holders off of, ie: 95 Honda…They are higher wattage and give better light.
They will not melt anything.
You can get LED's but hey, the incandescents work as well and last a long time. Be sure that if you go my route that you get the LL at the end of the bulb number as they are LONG LIFE better filament.
Home > Mk1 Golf Owners Club Wiki > Technical Guides > How to remove instrument cluster and replace illumination bulbs
Submitted by Hairyarse.
Thank you Mark1GLS and Briano1234 for the tips!
