Dash light troubles
(In Topic #221561)
Changed the three dash lights with new leds. Though the dash doesn't light up. Tried reversing the polarity since they only work one way but no go.
All fuses are ok.
Found these two wires not connected not sure what they are for.
All fuses are ok.
Dash light troubles
Maybe this could be a ground issue…
well, that is why I always suggest that for flakiness of the Dash.
Add a ground splice from Frame behind the cluster to the connector side of the cluster pin 2 brown.
Plumping the connectors using 1 strip of electrical tape on the pad side of the Tongue of the connector, you have to remove the shroud off the connection, then carefully lift the mylar place the tape and reverse.
Some one soaked their Star connector in a Rust eater stuff they bought at a hardware store, it was about 2 times stronger than Vinegar.
Only took about 2 hours and it was amazingly clean and renewed.
Never underestimate the corrosion between different metals…. Steel Ground point, aluminum or copper amp connectors, and pass a tad of current through it for good measure…..in as little as 3 years it can look like that, add a water leak and presto you have what you are seeing.
Besure to test the bulbs as to the polarity with a 9v Battery so you can then find which side of the lamp connector is 12v and ground…
Oh be sure that you have your headlights on and verify that the gray/blue wire has voltage as that wire likes to get fried and short out other wires…
Dash light troubles
Is this what you mean Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum
Yep, I don't know who wrote that… but it works for me.
I forgot that the headlight bulb is removed from the housing at the rear, and the bulb and the socket are a one piece item.
You can remove the Bulb and replace it with a tiny super bright led and resistor 700ohm soldered on the emitter to the Ground pin (brown) wire ide and the +12Side to the collector of the led.
I did that years ago to the Headlight switch and the Ciggie lighter, and even the bulb in the Ash Tray.
Dash light troubles
Thanks I somehow made it worse after cleaning the connectors the lowbeam isn't working.
Neverending story.
Btw what could this connector/wire do?
Isn't connected for some reason.
Neverending story.
Dash light troubles
After a lot of fiddling I finally got it working.
The low beam was because a powercable had loosen from the connector on my built relay.
