Coil pack
(In Topic #165678)
After recieving the engine back from the builders..refitted and connected everything back up…managed to start but not running well,very little power in 4th+5th,the engine builders advice is the coilpack maybe at fault,the coilpack that I had on was from a polo mk4 the one they used to dyno the engine was from a polo mk2
they have sent me the mk2 coil pack which I have fitted but now the rev counter is not working……arranged for an auto electrician to come this weekend but he has let me down
Anybody any advice this is the wiring on the mk2 coilpack presumed it was a simple case of connecting the middle 3 to the distributer and just connecting the + and - s up but now no rev counter?
Forgot to add the reason they used a different coil pack was because the new bottom end has an electronic distributer whereis the old one used a rotor
Last edit: by fisherman
then for the 3 pin all it needs is ignition live, earth and a wire from the ecu/dizzy to trigger it.
but looking at the state of that loom you should just bin it all and replace with a fresh loom from a mk1/2 with electronic ignition, plus as i say fit a std electronic ignition mk1/2 coil and 7 pin TCI unit. the 3 pin coils are rubbish, ask any MK3 owner how many times they had to replace theirs
