Clocks playing up...
(In Topic #188689)
Bit of a weird one, was putting a new set of clocks in and when i first put them in all lights flashed ie oil battery etc. But after disconnecing them to put light bulbs in and putting them back in its all dead….
Any ideas? I have no idea whats gone wrong. Any feedback or thoughts would b great!
Thanks,
Jeevs
After that, the long white plug in the bottom corner of the clocks has a power feed to it, from memory it's wire no1 - I could be wrong - but I'm sure it's the wire at one end or the other of the plug. Check you've got 12v getting to it with the ignition on.
Perfect, i will give that a go too. Im just puzzled as the PCB is all intact not worn away from anywhere…
thanks for your response Andy
check all the terminals are clean and straight, carefully bend any that are squashed with a pick or similar (watch out for the red wire its perm live, pull the fuse before you poke at it!)
check the brown pin has continuity to ground, if it was/is an MFA cluster it will earth to the side of the head brown/white wire with ring terminal. if non-MFA then it earths in with the main dash harness
Brilliant thanks John. Right its non-MFA so will take a look at the brown pin to ensure continuity.
Any other things you'd say i should pay attention to?
Thanks,
Jeevs
I will post progress later this evening - many thanks guys!
Long story short i ended up buying a new set of clocks. Tried them in today all seems fine. However, the oil pressure light stays on no matter what… any ideas on why this might be? I know i have oil because i did a full service on it over the past weekend.
Thanks,
Jeevs
