Changing number of headlights
(In Topic #196758)
I recently bought my first ever 1989 cabrio clipper (as seen in my profilce picture). It came with a debadged single headlamp grill, but I would prefer to change this to the twin headlamp, so I bought a new grill that came with the smaller headlamps.
My question is now how do I wire these extra lights up and what bulbs should I be looking for? I'm only 19 and this is my first ever project car so I'm a complete novice at this so please bear with me if this is a silly question.
Cheers!
Now sadly I can't answer your question my twin lamps are standard but I'm sure someone will come along this the right answer.
It would help a lot if you could post up some pictures of your wiring so we all get a better understanding of what you see!
Sent from my Mobile Phone whilst in Wörthersee, Austria for the GTI Treffer.
Instagram Firemandan1
This is what I currently see. I don't think I can see the spot light harness. I don't have access to the new grill as its currently stored away in the garage which I don't have the keys for. From what I can remember only the spotlights were present, no bulb or bulb holders.
Cheers guys
rubjonny said
follow the white wire out the back of the headlight plug, thats where the spot plugs in. it should also have a brown wire to it, which will be tapped into one of the browns there (usually also to the back of the headlight plug)
wow thanks John I looked and managed to find the loom.
now do I just need to buy the spotlight wiring loom? Such as this?:
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-SPOT-LIGHT-LAMP-WIRING-LOOM-CONNECTOR-CAP-LAMPS-/111690151521?pt=LH_DefaultDomain_3&hash=item1a01407661
rubjonny said
thats the one! your ebay link ares the right age spot light looms to match your late spec connectors
Would something like this be better? I've heard there can be a voltage drop so using a relay system like this can allow max voltage for the lights.
http://www.ebay.co.uk/itm/Vw-Golf-Mk1-Gti-Classic-Proffesional-12v-Spot-Lamp-Driving-Fog-Light-Wiring-Kit-/271389170279
the kit is designed to add a set of fog lights by the looks of it, you could just use the factory fog light wirign plug in the engine bay and fit the fog relay on the fusebox after swapping the fog power to B/20 as per factory VW wiring.
bit of scare mongering in that auction suggesting your loom will catch fire without one, its all fully fused by VW…
