Central locking went bananas!
(In Topic #184718)
What should I check next?
Website Manager
Website Manager
Could you operate the central locking from either door with the key ? If so then it is master master.
The micro switches in the solenoids corrode and cause what you have seen. You can separate them and replace the switches but the kits are so cheap it is not worth the time and effort.
Website Manager
Website Manager
The five wire systems are really simple once explained. The motor basically drives open in one polarity, then the opposite when reversed. The additional three wires is basically a limit switch. A common, an 'open/up' closed when up, and a 'closed/down' closed when down signal. If the central locking system isn't getting this signal, it'll keep trying until something breaks or burns out.
To rectify, the connection to the operating link (often tied into the actual door button via very small grub screw connection) has become loose or moved. I really disliked these connections to the push rods, so I started taking the solenoid connection direct into the door lock, using the lever that holds the door button. it's a very reliable means to providing this type of locking. Then its the position of the solenoid that ensures the correct solenoid travel is achieved.
If you followed that then, well done. It is a very simple operation once shown and I've experienced your very issue as you describe. Moving the components to allow full 'up' and full 'down' is probably the key to resolving your issue.
when fitting you need to remove the lock block from the door and slip it on the pin then refit, there is a flared out base that stops it falling off once fitted. if you put it on from inside the door the flare will be on the inside of the skin and so wont help. and they will fall off, from personal experience
I'm still waiting for 2nd 5 wire solenoid to arrive. The company I bought them off sent me 4 rolls of loom tape instead.
Is there any difference in the 2 original solenoids? The wires were a different colour combination? I've had to buy 2 of the same soleniods, hopeing that I could use them both.
you have an earth, lock pulse, unlock pulse, lock position and unlock position.
the lock/unlock position are earthed when triggered, lock and unlock pulse pop the actuator when you put 12v to them. if you get the lock/unlock pulse and lock/unlock position mismatched the actuator will go mental as you have found!
the cl brain triggers the actuator to lock, then instead of lock position signal it sees an unlock signal from actuator and then sends unlock pulse, then instead of unlock position it sees lock position and so sends a lock pulse. repeat ad infinitum
