Brake lights and Reverse light not working
(In Topic #206467)
Morning all.
Not used my car in a while so thought I would take her out with the sun shining. My brake lights and reverse lights don't seem to work yet the indicators and side lights do. Any ideas? It all worked fine before I put her in garage
check the fuses for starters, what fusebox is it early ceramic or later blade type
Thanks, didn't really think of the obvious. Its a later blade type, on an 83 tintop
right fuse 2 for brake lights, 15 for reverse
if they check out ok look in the engine bay next, check the black wire on reverse switch has ignition live, if you loop it to the black/blue the reverse lights should come on. there is a 2 pin plug inline with the wires check there for corrosion
for brake lights you got 2 pressure switches on the master cylinder, the red/yellow wire should be permanent live. if you loop to the red/black the brake lights should come on
That's a great helps, thanks. I will have a look this evening and fingers crossed get it all sorted
