Ballast resistor ?
(In Topic #182857)
I stupidly left my ignition switched on when checking my lights etc so it drained the battery and now I've got no spark, charged the battery back up and changed the coil, so guessing I've blown the ballast? Does that sound about right?
Cheers Darren.
1983 mk1 golf gti campaign
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
Is there anything else that could off blown or burnt out apart from the points and condenser?
Cheers Darren.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
Next question- Will this be a direct fit?? I've also got a mk2 gti with all the bits but not sure if it's compatible?
Any help will be great
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
here's the set up at the coil with points ignition at the mo.
and here's the electronic set up.
cant I just snip the lilac and white wire and use the black wire which feeds to the same connector?
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
cheers Darren.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
the feeds to the coil should run to the white D plug on the fusebox, see here (CE1 fusebox)
http://www.clubgti.com/showthread.php?219775
as i say you'll need a new coil as well the points ign one is no good
after removing the lilac/white & red/blk wires?
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
if you wanted to add a new pin its one of the large round ones, so not too bad to remove use a thin screwdriver to lever the lock pegs in, then pop a wire in chopped out of a donor loom. you can buy the pins new as well if you have a pro crimping tool
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
I havent tried starting it yet because the rotor arm is not in the same position
as it was before( about 15% off where it was with the points distributor)
S0 i guess the offset is different in the spindle where it sits on the bottom?
Does this matter?
Thnaks for your help, Darren.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
