Alternator help
(In Topic #217238)
Hi can anyone point me in the right direction
Hi can anyone point me in the right direction i want a new alternator as mine is wobbling all over and rattling theres a 65amp and 90amp option with different fittings which is best and which fitment thankyou also which brand is good quality and reliable also cant seem to figure out how the bottom bolt comes off ?? Thankyou
Well actually you have a few options.
If yours has the plug connections, then you can install a 65 AMP no issue.
You can also take yours to a shop and have it rebuilt, and possibly upgraded to a 90 or 120 A.
You can buy a 95 Amp with different fittings, and convert your plug to accommodate the newer style.
which would be 2 posts, one big fat one that the 2 red wires in your plug would attach to, and the little one that the Blue wire would attach to.
Hi thanks for your reply. Is there any performance benefits in upgrading to 90amp or even a 120amp .as this is my daily runner so it has to be a straight swap over job .thanks
Well if you don't have power windows, and don't want a bass boost then stick to what you got. Then you don't need the 90, or the 120.
If you want to run a large sub, and amp, then upgrade.
Thanks for clearing that up mate no ive no power steering and no plans for a big sound system so il stick with the 65 cheers mate
