Accidentally short-circuited my tach meter. Please help
(In Topic #242176)
While reinstalling my motometer (including MFA) from a VW Golf MK1 Cab 93, I accidentally touched the circled area while the car was running. I felt electricity on my finger and I instantly saw my rev meter falling to zero.
I took it out again, checked continuity from pin 5 to the connector, checked the 14v to 10v 3pin regulator as described in this forum, I checked earth, all is good.
Symptoms are the following:
- Tach meter does not work (stays at zero)
- MFA Rev meter also shows zero, when doing the key on-off-on procedure to access the "hidden menu".
- MFA AVG lt/100km does not work as well
- The rest all work fine.
Any help would be greatly appreciated.
Cheers,
All the continuity of the 4-pin connector to the tach meter is fine. They go to 12v(pin 14), ground (pin 2), red/black cable (pin 5) comming from the engine bay, and the fourth pin is also well attached.
The question is: Signal to the RED/BLACK cable comes from Digifant ecu or from the igmition coil? On Haynes manual is on diagram 97-9190, the G5 index.
Never took one apart.
