1.8T coil packs
(In Topic #201309)
I recently bought a used Emerald K6 ecu and harness from a forum member for my 1.8T project. I have a problem because my coil packs are 4 pin and the harness for the emerald ECU are 3 pin plugs. Is there a benefit to running 4 pin coil packs and altering the loom and reconfiguring the ecu or shall i just buy 3 pin coil packs?
Many thanks
Kris
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
however you may find if its running big power the 3 pin type are not man enough so then people go to the 4 pin coilpacks which each have their own spark amp built in.
If you dont have the separate spark module currently you'll have to get your ecu reconfigured to work with 4 pin coilpacks as the trigger signal is different
