1.8kr conversion
(In Topic #235507)
Wiring advice
Hi all.
think I’m ready to change my sons old 1.9 d for a kr 16v on bike carbs. My query is…
1. can I change the diesel cold start relay to then allow me to use the 12v feed wire? If so change with what relay?
2. on the 16v ignition loom where should I be connecting the red/yellow (fuel pump relay earth trigger) and the black/yellow (idle feed) as my donor car is diesel. I am using a supplied inline fuel pump for bike carbs. Thanks in advance🙏
Last edit: by James Tate
Regional Host NE
Re: 1.8kr conversion
Will watch this one with interestJames Tate said
Hi all.
2. on the 16v ignition loom where should I be connecting the red/yellow (fuel pump relay earth trigger) and the black/yellow (idle feed) as my donor car is diesel. I am using a supplied inline fuel pump for bike carbs. Thanks in advance![]()
Sent from my SM-G975F using Tapatalk
