was this grill ever on the cabby
(In Topic #167531)
My car is a 1990 gti cabby, can anyone tell me did they ever have this grill on them . I think I would prefer this to my existing one,
also what do you connect the lights to, main beam or switched seperately.
my current grill
Grill your car would of come with when new.
If you want to fit it to your car you will have to find someway of fixing the lower screw in the headlight grilles as the 'Clipper' type cars have a large hole where the screw needs to fit. Seen comment that VAG did a 'conversion' kit to overcome this problem but don't have any details. Would be interested to know how/ where to get this kit as I have fitted the earlier grill to my '89 Cabrion.
mark1gls said
Thanks for that mark1gls, will see if I can make it fit and see how it looks. the one I have on I have seen for 20 quid on ebay, so if I bu**er it up not the end of the world .
Golfie1157 said
I think the earlier Cabriolets (pre Clipper bodykit) came with this type of grill but not 100% sure whether any had the red trim. Certainly some had the silver trim.
Thanks for that, will have a play and see if I can make it fit, can always put a cheap single lamp grill back on
As Tony's says your car would have originally come with the inner spotlights and your current grille is an after-market de-badged late cabriolet grill. In terms of the spotlights it just depends what happened with the spotlight connections when the the new grill was fitted as to whether you can easily plug and play with the older grill..
PS just noticed that you are missing the separate headlight grilles which I think you are aware of. i.e. the later grill is one piece whereas the older one is 3 piece. The lights you have could be spotlights that come on with main beam or fog lights. Both were offered as either standard or after-market options primarily for hard tops at the time.
Golfie1157 said
it will definitely fit. I have been driving around without the lower screws for a while with no problem.
Will check wiring this weekend, I assume these are the bits I need to make it work, will order these and give it a try.
Thanks again.
In terms of what it will look like, see the Christmas Cabriolet CC picture at the top of this website Home page. PS this does not have the Clipper bodykit but will give you the idea
Golfie1157 said
Yes , These are the 2 parts you are missing.
Ordered the end pieces yesterday, sanded and re-painted the red trims today, will check the wiring is there tomorrow ,need a gti badge and vw badge for centre of grill now.
