91 Golf Clipper - Hinge in Glove Box
(In Topic #229967)
Replacing Hinges in Glove Box
Hi all! In my "new to me" Cabby, one of the hinges is missing in the glove box used to open the door. I would like to replace both (seems easy enough), but I am having problems finding the correct hinges. Any ideas? Many thanks !
need a better lighted pic, as it looks as if the hinge is there but the pin is missing, fo that you can buy a Dowel rod or a Screw/bolt for the pin.
Thanks so much - here's a better photo, with the parts circled. As you can (hopefully) see, the part on the right is fine and intact (it's what's holding the glove box door in - but the part is just old). The part on the left if missing all together (the screws are still there for some reason). So, I would need both the hinge part and the dowel
rod.
