Sunroof seal fitting advice
(In Topic #172851)
Gotta fit a new sliding sunroof outer seal and was wondering if it makes any difference where the join ends up, looks like the original join was halfway along the shorter edge of the panel on the drivers side but I was gonna join it halfway along the longer rear edge, does it make any difference though ?, any advice appreciated
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
I could be wrong as it was a few years ago I had a Mk2 golf with a steel sun roof.
Thanks for the reply
when refitting take care not to push the inner trim inside the roof hole, you cant fish it out unless you remove the outer panel again. made that mistake before
and you want the roof seal join to be half way along the side as per factory. if you put it at the back as suggested above you'll find it keeps getting pulled off when working the sunroof
