Seat base cover
(In Topic #204551)
Seat base cover
Search for seat refurb by chortle in the how to section
I go into detail on taking the seats apart etc. I've done this before.
You can lift the cover and cushion away in one go.
But turn the cover edges inside out when you come to refit makes things easier.
The cloth base is attached by rods that hook into the foam cushion wires. Simply compress the cushion to give you slack if your changing them over onto different cushions.
The seat foam cushions and covers are the same for drivers or passenger side.
However the metal seat bases aren't as they have the seat belt retainer as set for each side.
Neither are the back rests as there are slits where the seat tilt mech comes through.
Take a look at my how to good pics there too.
buy as above dead easy to split. poke 3 log pegs out of the trim plastics in the corners and unclip, tilt seat then pop off the 2 circlips at the tilt pivots and off they come
