Scuttle replacement
(In Topic #195614)
I am looking for advice as to repairing my scuttle panel, i have a fair few holes along the windscreen seal and wondering if it would be easier to just cut the rough parts out or replace the panel all together.
I have a welder but i am by no means a professional and i have zero bodywork experience, just the will power to want my mk1 back on the road asap!
Here are a few pictures..
Any help/advice will be much appreshiated.
Drive like you mean it!
The lip is 2 sections, inner and outer spot welded together. Hardest part will be cutting a pillar neatly.
When it comes to welding a pillars will i have to build it up as they are layered?
Still yet to remove wings and bonnet but once i get those off hopefully it will become clearer.
Sorry for all the questions!
I see the tab your on about looks like its spot welded in too.
Im hoping its just the top layer but still need to cut the rotton section out to see.
When you say brace it you mean the roof if i do need to take the whole A pillar out?
Lastly, what did you do with inner seal(where it joins scuttle) mine has rusted through there too, does this come with replacment panel, different panel altogether or will i need to fab something up?
Tom
Which inner seal are you talking about bro? Pic would help.
Wings are a pain, heat works
A member had pretty much the same issues.
He cut out the whole bottom section and both A pillars.
But he only cut the A's as high as he needed to, so not the whole pillars so that when he had donors he could chose where the join was.
It was about two years ago and he made an excellent job, when painted you really couldn't tell the difference!
Not much help I know but I thought I'd mention it.
Sent from my Mobile Phone.
If you have a look at the second and third pictures down at the begining of this thread it shows the holes as if you were sat inside the car looking out of the windscreen(dash has been removed)
Thats the bit im on about!
Any info/help much appreahiated
Cheers guys
Is picture 4 the bottom of the 'A' pillar on the N/S? if so, expect more rust inside, it looks just the same as mine was. I ended up replacing 2 layers of the 3. I think I went in to detail about how I did it, check my resto thread out for reference.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=projects%2Fyour-mk1-golfs_2%2F-83-gti-set-to-get-full&start=520
Andy.
I had a scan though Drapoon's posts but couldnt seem to see much about replacing scuttle + measurments, do you know which thread it was on?
Thats the drivers A pillar and yep i have cut a little section out, it has pitted badly on the second layer so will be replacing that too! 😔
My worst concern is picture 2 and 3 which shows the opposite side to the scuttle (inside the car) i guess i should be able to source a panel and cut that section out but its going to be awkward, just hope its not too bad behind it where water may have collected.
Thanks for the link to your thread will definitley come in handy
Thanks again.
Tom
I have read to buy genguine panels but now i know to double check with windscreen too before final weld, something i probably wouldnt have done!
Thank you 👍
There is a guy on FB who is stripping a few mk1's at the minute, he may be able to help you out. I'll PT you some info.
Scuttles on its way, bought from crazy quiffs in the end little more expensive but know it will be good and i have next week off so can make a start getting the old panel out.
This weather lately makes me want the mk1 running more than ever 😩
My replacement panel turned up yesterday, have spent a good couple of hours today going back and forth seeing hows best to tackle the job.
Below is a picture of the amount of panel i have to play with behind the scuttle, i think rather than drill out the replacement panels spot welds along the bottom windscreen seal i may leave them be and run a weld along the inside edge as i need to replace most of it anyway 15mm ish down from the lip as you can see in pictures at the begininng of the thread.
(Bit blurry sorry!)
As for the bonnet hinges i was going to leave those joined to the chassis and cut the new panel to fit around them?
The only other thing im not really sure how to go about is welding the guttering on the a pillar. I need to replace the bottom section of gutter so will obviously need to cut into the top two layers but as it shows in the picture below the gutter is folded back on itself and over the top of the top layer. Its going to make it tough to weld to the rest of the existing a pillar, unless i can weld the gutter once i have the top layer in place?
I hope you can kinda understand what im trying to explain! Any advice much appreshiated
Made this up to unpick the gutter
Im guessing this will straighten out ok when i fold it back over?
I noticed on your thread Andy that you folded the gutter right up too. Was definitly the most tricky bit but now i know how it all fits i feel a lot more confident to start cutting into the chassis.
How do you measure out the a pillars to get the length right as its awkard to get a proper measurement from anywhere.. Or do you use the old panel as a template?
