Scuttle panel repair
(In Topic #222183)
I’m going to repair the severe rot in the scuttle panel, and here’s how I did it for anyone else who is needing to do this job…
First remove the dash, windscreen, wiper motor, and in my case the bonnet.
Buy a replacement panel - I bought a klommer something one.
Regional Host NE
and the rest of the of the installation must
be to follow need to do the same repair
I see that is a LHD drive Panel do you have to Drill a hole for LHD and if so what are the measurements.
Yes it’s a LHD panel as that’s all that was available , so yes you have to weld up the holes in it and drill some new ones.
Briano, I’ll get you the size of the hole as soon as I can matey
Regional Host NE
klommer germany more euro car parts sh1t
Sooo, the new panel is a reproduction and it’s such a poor quality, I decided to cut it up for sections.
It’s a poor fit and the metal it’s made from I am not convinced is of a similar quality…
This also saves removing the front wings
I prefer to make the section/make the section fit nicely before I cut anything out.
Regional Host NE
but surely everthing is out of place
Regional Host NE
is that now in place that you are happy to secure
it to the original scuttle panel
Everything stays in place, more so than putting in a panel that’s not the right dimensions or shape. In fact I get to keep the bonnet gap
I need to fabricate a section for the inner
I’ve left the bit with the hole for the RHD wiper , so I can mark the new section from underneath - then I’ll cut that out
It’s clamped up tight to the existing , and both bits repeatedly trimmed, until it’s a nice fit and importantly- to the exact same dimensions - I want the windscreen to fit afterwards!!
I intend to form a jiggled joint, with a 5 - 10mm overlap, but had to stop as I have lent my stepper tool out
And start getting the other side ready
Get my Shrinker/stretcher out and start forming a piece for the inner windscreen frame, this is fun (not)
So I put 3 - 4 tack welds in critical places and then tried the windscreen for size - looks ok and the job still makes sense , I haven’t made a major error (apart from ever starting the job!)
Then start tacking in place
I’ve been told that current practice is a light coat of acid etch primer before applying filler - so here goes..
Good and quick work there.
Keep it up mate.
Keep it up mate.
