Remove Clipper bumper trim
(In Topic #224121)
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Remove the 2 big screws on the ends.
The push the bumper against the rebar while doing this.
The carefully pry the, out with a little screw driver a little bit at a time….each wedges,
I suggest that you work on the center ones first as if you break an end one that makes it harder to keep it on..
By wedges and bigs screws, do you mean 21A and 16 respectively?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Are they supposed to be?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
WD worked a treat BTW.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
stuff, I had to use a craft knife to cut it then I could peel the black glue off.
I did not use any glue/tiger seal when fitting it all back together.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I made up a little ball with it and managed to roll the left overs off the bumper using the ball so the bumper was clean.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
https://www.heritagepartscentre.com/uk/N90634901-pop-rivet-for-wheel-arch-trim.html
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I have a couple of types of these things…
if you have never used one see: https://www.youtube.com/watch?v=WPwNsQMnx88
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Makes it easier next time I pull the bumpers off.
You make it sound like a weekly occurrence
Bolts might be a good solution
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
They used Natural un-vulcanized rubber rollers and as a lark I took a used set and left them on a window ledge with a large paper clip between them after about 7 weeks, it absorbed the clip. After about 6 months it turned to goo with the paper clip on the bottom.
In my misguided youth we learned the difference between Rubber seals the hard way. Rebuilt the master cyl/Clutch combo that the early MG's had….. including the Calipers and all the wheel cylinders….. Used the wrong type of Brake fluid and a week later, well lets say I had to rebuild everything again as the seals were Destroyed by Wagner Dot 3 fluid…….Natural Rubber Seals don't like the US fluid…. After cleaning and flushing everything out, started to use Castrol GT/LMA didn't have to rebuild anything ever.
