Rear and side tension cables on cabriolet starting to show
(In Topic #234622)
Rear canle is sheathed and seems to be too big for the channel in particular!!
All seem tight though and roof looks ok apart from the cables showing (at rear and on one side)
If you look at page 16 of this guide how to fit a new hood it shows you what to do.
Cabriolet Hood Replacement - The Mk1 Golf Owners Club
The cable may need to be undone slightly so check what thread is left on the ends incase you need to take up any slack.
Do you have both loops of material for the hood cover?
I can only see one in the photo.
As a note the headliner at the 1/4 sail panels look to be flapping and you say you have an issue with side tension cables too.
Do you have photos of that issue.
I’m over in Derby (not sure where you’re located) if you want an experienced person to look at it for you.
Regional Host NE
chortle said
Careful you don’t chip your paint or damage the hood.
Chortle - I’ve heard you are the go-to guy for roofa but I’m in South Wales so a bit far really!
Headliner 1/4 panel was loose and has been put back right now and clipped on the hooks
There is only one loop at the back - should there be two and what are these for?
The lip doesn’t seem to be big enough to tap the cable back in!
Do I need to look to tighten the cable as I do it and if so where do I tighten these - are the nuts easily accessibly for both rear and sides?
Hooks on the cover go through loops to keep in place.
I think I know this car.
Notts car then went to Brum.
Easy to have a chat on the phone.
I’ll message you my number.
