outer scrapper seal clips cabriolet
(In Topic #219794)
Hi to all!
i have just bought new outer scrapper seals and some scrapper clips for my "88 cabriolet, as some of them are missing.
How do i install the scrapper clips in place? do i have to push them in place with a long screwdriver from the gap between the window and the door?
thanks in advance
thanks in advance
Just as you state. There are locations inside the door metalwork. Lower the window and remove the seal.
You should be able to see the location of the trim clips. Replace as necessary. Once fitted, fit your new window scraper seal.
Don't cut the scraper seal too short. Your original seal would have probably shrunk.
Sent from my H3113 using Tapatalk
Here is how I did it, and there are pictures of the clips.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Freplacing-the-outer
