Hella spot light cleaning
(In Topic #194104)
To be honest having realised how rare the fogs were I was a bit daft to risk it, but if it was a case of spots which are much more common, and I was prepared to replace them if it didn't work I would give it a go, unles anyone has some better tips. Must say though, I now have a steam cleaner with a flexible nozzle - that might work, again may need distilled water to stop marks.
just had another thought - are they hazy on the outside - if so some cutting paste or something like Barkeepers Friend may help, particularly clean around the edge of the glass.
Mine are milky so will get around to it one day but more important jobs to do before I get to it.
http://sciroccoregister.co.uk/carforum/viewtopic.php?f=13&t=17921
this gives you better access to clean the inside lamp
I used clean fresh rag with very little washing up liquid
then got long screwdriver to move rag around front and back of lamp
wash lamp out with fresh water then dry with clean dry rag using screwdriver
you can tape up tip of screwdriver with masking tape
its just a case then you putting bulb holder back and tapping the tabs back down
leave front of lamp down on couple of rags when tapping tabs back down
It made quite a difference, just change the wadding regularly.
Ok here's a link to my post but go to the 1st of March 2013.
This is how I did mine but please feel free to read all the other suggestions because I'm sure they work just as well.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=mk1-golf-chat_2%2Fcleaning-the-inside-of_2
Please do share your results!
Sticker Pig
