Heater box pipe work
(In Topic #208600)
These are the two pipes I am talking about
Then slide the grommet from the engine side of the firewall to the frame. Once that is done then you can judge the cuts.
If you have a hose cutter (looks like a scissors but cuts hose ends square) it is easier to judge.
You could also measure your old hoses and cut to match.
One hose is going to be about the right length, the other you will trim to fit the heater valve. IIRC the piece that I cut off of that one I used to connect the heater valve to the hard pipe.
I wasn't using the silicone hoses but the standard rubber ones.
