Headliners - Help
(In Topic #211746)
I dont know if some of you may know of or used the Newton Commercial headliner. Those that have will know that the main roof section is a slightly different material grain from the original. If you dont then this topic explains it well
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=bodywork-fittings-and_2%2Ftrying-to-find-correct
Anyway i know there are some people out there that would prefer to have the main liner like the pillar pieces which is more like the original larger grain pattern. The reason for Newtons being this way is that the pillar pieces are vinyl and the main piece is headlining material not vinyl and they have not been able to source the exact headliner material for the roof piece.
So today they have found a close match to the original pattern for the center piece. I am now looking for someone to fit a sample that they are going to supply me to see if this material works well enough for them to swap it into the headliner kits and replace the one that isnt quite right, We would need feedback and images of the fitting and what the material is like to work with. Ideally someone that has fitted one of these before as i know its not an easy job. The one they are going to cut me is a 3 door with sunroof in black.
If you can help then please let me know
Anna @ VW Heritage
