Front Seats wont tilt
(In Topic #201573)
Golf MK1 Rivage cloth front seats wont tilt forward
also should the rear seat fold forward as mine doesn't any help advise would be greatly appreciated.
Many thanks.
for the rears you need to open the boot then pull the knob on the left/passenger side, then go back inside the car and pull the rubber strap on the left/passenger side to allow the seats to tilt. the strap often goes missing, but if you climb into the boot and follow the control cable from the release knob you'll find the lock lever on the seat, flick that up to allow the seats to fold then replace the rubber strap
One of my cables has snapped so I just a bit of wire to hold the lever up out of the way.
The front seats I noticed that the reason the side levers wont go up is they are up and when I push them down they spring up slowly does that mean the cables are broke?
Cheers,
