Front seatbelts
(In Topic #207819)
I have an issue with my front seatbelts where they don't automatically return back in once unclipped. They do return by they need a little help guiding them back in.
I know it's a common problem and is most probably caused by the seatbelts having too much friction I suppose to return
I remember reading a post where there are home remedies for this involving either a spray or heat? Can't be 100% sure though!
Does anyone have any suggestions?
Mk1 1983 Helios Blue GTI Engineering
pull the seat belt all the way out and spray it on and polish it off with a cloth and work your way long the seat belt till it's all the way back in the pull it all the way out and in a couple of times.
Worked well for me.
I had also noticed that the belts retracted fine when I removed the cover over them, as somehow it was adding friction or impeded the return.
I also replaced the retractors on the belts with ones from the Rear Seat of a Jetta, and still had retraction issues.
Cleaning the belts was what was totally needed.
Here is a how to that I did shows how to remove the belts from the retractors.
Replacing Slow Seat Belts in Cabriolet | Volkswagen Owners Club Forum
Last edit: by Briano1234
I think I'll try thto first method first as it seem the most easiest! Lol
Will def give this a go on the weekend because it's becoming so annoying having to constantly guide the seatbelts!
